Platform: J-body
94 cavalier ignition switch
Old May 4, 2010 | 1:36 PM
marbar64's Avatar
Default 94 cavalier ignition switch
Ignition key goes back and shut the car I need help to remove the switch.
Problem solved! the part that is defective is the switch in the back of the drum (where the key insert)
Old May 20, 2010 | 9:33 AM
vortec02's Avatar
if its the same as 99 you should be able to take the plastic off around the steering colum turn the key to "run" NOT "START" theres a pin in the side closest to the steering colum on the front side near the gauge side while key is in "RUN" push the pin and slide the cylinder out
boho115
Jul 10, 2013 7:15 PM
Truck Driver Bill
HHR
Aug 11, 2011 8:48 PM
leejosepho
Oct 26, 2009 10:51 PM
eddiek777
Oct 25, 2006 12:24 AM
RedE2go
Sep 14, 2006 2:30 AM
