Platform: J-body
96 Cavalier won't start
Old Jul 25, 2006 | 8:28 PM
Iron Horseman's Avatar
Default 96 Cavalier won't start
Hi. I have a 96 Cavalier with a 2.2. It started starting slower and slower until what I figured the battery went dead. After having it tested I replaced it. Now the engine won't crank. I took the starter to have it tested and it checks good. No fuses are blown and all test good with a continuity meter. I cleaned all the grounds but still nothing. When I turn the key on I can hear the relays engage under the hood but that's it. Any help is greatly appreciated. Thanks, David.
Old Jul 26, 2006 | 10:30 AM
Nomad76lj's Avatar
Default RE: 96 Cavalier won't start
check the oil. did it make any bad noises when you where trying to start it before the battery was replaced
Old Jul 26, 2006 | 1:12 PM
The oil looks great. It has only about 700 miles on the change. As far as noises go it started making a noise that sounded like the cat was rattling or a loose heat shield but before I got a chance to check it it quit.
Old Jul 28, 2006 | 2:10 PM
beckeruti's Avatar
turn the key on and and jump the starter out with a screw driver
if it starts its probably the starter
if it doesnt u dont have power going to the starter
just search back from the starter
ZChevyAK
Nov 13, 2015 6:45 PM
jr1017
Apr 24, 2012 7:00 PM
bracca
Jul 12, 2009 6:14 PM
FamilyOf5
Jun 11, 2008 2:56 PM
ofisa
Aug 22, 2006 1:33 AM
