Platform: J-body
97 Cavalier Stalls but Restarts only after sitting for awhile
Old May 7, 2007 | 4:20 PM
kjracer103's Avatar
Default 97 Cavalier Stalls but Restarts only after sitting for awhile
I have a 97 Cavalier Z24 that will stall when accelerating from a stop but only after it is warmed up. It will not restart until it has sat for awhile. When trying to restart the car right away it feels as though it is lurching some like the transmission may be slightly engaged. I'm thinking fuel filter or fuel pump but was looking for other suggestions before I start to throw money at it.
Old Jul 3, 2007 | 3:54 PM
kjracer103's Avatar
Default RE: 97 Cavalier Stalls but Restarts only after sitting for awhile
Well nobody here had the answer so I had to find it on my own. It was the crank sensor. $20 part.
Old Aug 7, 2007 | 1:21 PM
garye's Avatar
I have the exact same problem to a tee with my 95 Z24 cavalier. Already changed the fuel filter and fuel pump, no dice, still have the same problem. How did you decide it was a crank sensor. My mechanic could not figure out what was going on. I have not yet fixed the problem.
Old Aug 7, 2007 | 4:23 PM
kjracer103's Avatar
There are a limited number of things that can actually cause this. It acted like it wasn't getting any spark. The crank sensor will get hot then just quit. The computer doesn't pick this up which is why there isn't an error code. For around $20 and a half hour to hour of time you can check this out. Plus, if your car has a lot of miles on it the sensor could stand to be replaced anyway.
Old Aug 7, 2007 | 8:24 PM
garye's Avatar
I took it to the chevy dealership here and told him to check the crank sensor.Helooked at me like I was nuts. He didn't write anything down and said he'd call me onWednesday. I'll see what he says, if they did not check that Iwill make sure they do beforeI pick it up. Thanks for the tip.
Old Aug 8, 2007 | 8:55 AM
kjracer103's Avatar
It didn't show up on the diagnostics when I had them done. The dealership told me it was the Ignition Control Module but when I replaced it that didn't do the trick.
Old Aug 11, 2007 | 11:22 AM
SAF's Avatar
SAF
i have a 2000 that's doing about the same thing, though it's usually if i'm on the highway doing between 65-75 mph. not when i accellerate from a stop. noticed the oil light and battery light coming on after the car stalls, but the oil's fine. hoping it might be a weak battery.
Old Aug 16, 2007 | 11:17 PM
garye's Avatar
My 95 continues to have the same problem. Chevy dealer put in a new computer PCM, didn't work, $500.00, then a new fuel filter, the old one was ten days old, fuel pump, the old one was 3 months old, then they told me they changed some sort of spring. The car doesn't stop now, but it still lurches like it's starved for fuel. They said they checked the crank sensor and no problem. I'm at about $1,000.00 now and problem not totally solved.
Old Aug 18, 2007 | 5:52 PM
SAF's Avatar
SAF
turns out mine was a bad fuel pump. car was still under warranty so they replaced it for nothing and it runs fine now.
mikeatpriestlake
11
Apr 11, 2014 10:00 PM
WSPrebs
May 23, 2012 3:50 PM
Joewill2848
Apr 22, 2012 8:12 PM
tristanpop
Aug 24, 2006 10:44 PM
