Platform: J-body
98 2.2 Theft light....
Old Jul 5, 2012 | 5:53 PM
98JunkCav's Avatar
Default 98 2.2 Theft light....
The car will crank and almost fire then the ignition gets cut. I realize there are a few threads on this when searching but I still have a few questions. My theft light on solid, doesnt flash. I have tried leaving it keyed on for 10 minutes but the light never goes out. All the fuses are good. From what I have read it needs an ignition cylinder replaced? Before I spend any more money on this I am just trying to see if it could be anything else needing replaced.
I just got done replacing a head gasket, the only plug I couldnt get put back was the plug by the AC compressor. The only other plugs that could be questionable are 2 injector plugs and the spark plug wires. Not sure if this stuff could be the cause, just wanted to mention it.
Thanks
Old Jul 7, 2012 | 8:39 AM
98JunkCav's Avatar
Anything?
Old Jul 7, 2012 | 9:16 AM
kevinkpk's Avatar
I don't know. I'd say try anything. I would try with key on, pull the anti-theft fuse, then key off, reinstall fuse.
Old Jul 15, 2012 | 3:12 PM
98JunkCav's Avatar
New lock cylinder did the trick.
hoghollow
Nov 11, 2011 9:56 PM
TBFire
Mar 1, 2011 11:48 PM
john52
Dec 8, 2009 6:18 PM
rob210
Nov 29, 2008 1:19 PM
Skrappi69
Sep 28, 2007 12:08 PM
