Platform: J-body
98 cavalier wont start
Old Jan 24, 2012 | 6:13 PM
  #11
EinST's Avatar
Well, we all had to start somewhere, though, I would've run and not walk away from a vehicle with unknown wiring modifications. For all I know, this may turn out to be a kill switch or the aftermarket alarm system he's not sure of. There may also be modifications under the hood. Headaches.
Old Jan 26, 2012 | 6:19 PM
  #12
98cavalierguy's Avatar
ok the air filters fine. and theres no codes popping up. the plugs are definitely getting gas when i take them out i can see a little gas on them so im assuming its not getting spark.
Old Jan 26, 2012 | 6:50 PM
  #13
EinST's Avatar
Okay, then, you may have a wiring problem, defective CKP sensor, or defective ignition control module (ICM). The PCM usually don't go overnight but who knows. Make sure you have battery voltage at the IGN fuse with key on (check it with a multimeter through the probe holes on the fuse). I think AutoZone will test the ICM for you if you take it in. Sign up for their free membership and see if you see anything useful in their repair guides.
Old Jan 30, 2012 | 5:28 PM
  #14
ok heres and updated video i cleaned all the fuses and tried to look over all the wiring, sprayed some started fluid in and it almost started. So it runs on starter fluid. anyone have a clue what could be wrong now?
Old Jan 30, 2012 | 5:29 PM
  #15
heres the video 98 cavalier update video - YouTube
Old Feb 5, 2012 | 8:26 AM
  #16
anyone have a clue?? it starts on strater fluid
Old Feb 5, 2012 | 12:44 PM
  #17
EinST's Avatar
Okay, at the risk of another episode of one-way conversation, I really think you should stop playing with the starter fluid. Tow it to a shop before you get hurt. Years ago a good friend of mine lost a finger fiddling around with his "new" ride. He finally got it running, drove it a couple of years, and then gave it to his younger brother who ended up flipping it over and getting himself killed. It was rather unreal like that "Christine" movie.
sleepingciv
Jul 25, 2020 1:03 PM
jmocka
Jun 7, 2008 5:08 PM
biged
May 20, 2008 12:49 PM
imjdoggie
May 4, 2007 2:05 AM
Bootman
Dec 29, 2006 8:27 PM
