Platform: J-body
98 Cavalier wont start
Old Apr 24, 2012 | 7:14 PM
Jaeaey58's Avatar
Default 98 Cavalier wont start
I have a 98 cavalier 2.2. It died on me going down the road, i hav sprayed starter fluid in the intake and it runs till the fluid is gone. i have changed the fuel filter it was nasty, and the theft light is on all the time.
Old Apr 24, 2012 | 8:05 PM
Check the fuel pressure. Signs point to the fuel pump.
Old Apr 24, 2012 | 8:07 PM
Jaeaey58's Avatar
changed the fuel pump too, forgot to mention that =[ checked the relay its getting 12v to one peg, and .01v on another and nothing on the other 2
Old Apr 24, 2012 | 9:40 PM
EinST's Avatar
When "the theft light is on all the time," the vehicle theft deterrent (VTD) system has declared a Passlock tamper condition. Check the CLUSTER fuse and CLS/PCM fuse in the I/P fuse block. Also, measure the voltage at those fuses. The CLUSTER fuse should have battery voltage at all times and the CLS/PCM fuse, with key in RUN or START. After that, suspect either the I/P cluster (includes the VTD logic), ignition lock cylinder (Passlock sensor integrated), or wiring between.
Old Apr 24, 2012 | 11:45 PM
Jaeaey58's Avatar
ok i will deff check that out tomorrow
Old Apr 25, 2012 | 4:19 PM
Jaeaey58's Avatar
dont u hate when its the simplest thing, well i was checking the fuses like u said to, and lo and behold there is a f/p - injctr fuse..... i pull it out and it was blown to hell and back, put a new one in, cranks up and runs like a dream.... theft system light is still on all the time, not blinking. im just happy it runs now!!!
Old Apr 25, 2012 | 5:31 PM
EinST's Avatar
Congrats. On your Passlock issue, it's apparently in the fail-enable mode. You may want to get it looked at since the minute you disconnect the battery, you won't be able to start your vehicle again.
Old Jun 22, 2013 | 3:45 PM
Jaeaey58's Avatar
Default Again!!!
Well i am back yet again with the same car. It cranks ok, little bit of a rough idle. it wants to die but then it idles up and is ok for a few, then rinse and repeat. it will do that untill u turn it off, if u try to drop it in gear it dies just about automatically. Also, it has been wanting to stay running after you turn the ignition off. i have done research and that could b the igniton switch. I am on a very tight budget and need this car to get to and from work, i have nobody that has a fuel pressure gauge, and it does not have the little test port on the fuel rail =[ Changed the plugs today, one had a huge crack in it. But to no avail it didnt help at all.
sleepingciv
Jul 25, 2020 1:03 PM
jmocka
Jun 7, 2008 5:08 PM
biged
May 20, 2008 12:49 PM
imjdoggie
May 4, 2007 2:05 AM
Bootman
Dec 29, 2006 8:27 PM
