Platform: J-body
Cavalier shifting problem
Old Dec 6, 2012 | 10:29 AM
Gabety's Avatar
Default Cavalier shifting problem
I have a 1995 Cavalier with an intermitant problem. After the car has been running for some time, say 50 miles or better without being turned off, it will die at stops. As I slow the vehicle to stop I realized it was not down shifting. Killing as if it was a standard shift and not using the clutch when stopping. If you start it back up it runs fine but as soon as putting it in D it dies. If you use a little brake and throttle up you can get it to 1 gear and get underway again. As long as car remains at a suitable speed for the gear range it's in there is not problem running or shifting up, just down as you need to slow and stop.
Like I said you have to have driven the car for awhile before this would begin to happen. I had the transmission serviced and seemed to cure the problem for a time including on long drives. I did not mention this to my GM dealer when the trans was serviced and I thought that had cured the problem. Letting the car sit for a while, 15-30 minutes will allow "normal" operation again. I like to try with advice here to fix this myself it someone has suggestions. Thanks
munroap
Oct 2, 2014 12:40 AM
ekristich
Jun 15, 2010 12:22 AM
Hobbydad
May 21, 2010 7:51 PM
jjohnson
Feb 15, 2007 6:44 PM
