Platform: J-body
clutch wont bleed.
Old Apr 18, 2014 | 12:39 PM
shanedaff's Avatar
Default clutch wont bleed.
after replace the clutch, pressure plate and slave cylinder in my 2001 2.2 it wont bleed. there doesnt seem to be air in the lines but when i took the lid off the reservoir bubbles came up. we've trying to bleed it for days now. any suggestions would be appreciated. thank you
Old Apr 18, 2014 | 10:42 PM
therewolf's Avatar
Hello, shanedaff, Welcome to the Chevrolet Forums.
It's been a while since I've done this, but IIRC, you have to get
pressure at the clutch master cylinder first. It's the same procedure,
pretty much, as bleeding the brake master cylinder.
1. Leave the CMC bolted to the firewall, if it's not level, gently raise
the rear of the vehicle till it is. Use proper support after jacking,
2. Bleed the CMC, using a tube from the CMC bleeder screw back into
the CMC resevoir. Pump gently, so as not to splash fluid about.
3. Then when you pop the bleeder screw at the slave cylinder,
it should purge the air downward thru the line from the CMC,
(keep a CLOSE eye on the fluid level) to the CSC.
4. Basically, the slave cylinder is the most remote item in the hydraulic
system, so it bleeds last. Once you purge the air from the line thru
the slave cylinder, the slave cylinder should bleed fairly easily. Once
you are done bleeding the CMC, top off the CMC resevoir every couple bleed
attempts, and keep the lid on the CMC as you bleed the line and slave
cylinder.
BE EXTREMELY CAREFUL NOT TO GET HYDRAULIC FLUID ON THE PAINT.
It's very caustic, and will strip your paint in an instant.
Old Apr 18, 2014 | 11:12 PM
systems with hydraulic release bearings are hard to bleed. After trying bleeding the master, gravity, vacuum and pressure bleeding one system I still had no pedal. Even after 2liters of fluid went through the system.
the only thing that worked was 10 fast pumps then holding the pedal down for 1min. then while still keeping the pedal down have someone crack the bleeder. repeat.
Old Apr 19, 2014 | 2:39 PM
therewolf's Avatar
I have to agree. You should also try this.
Old Apr 25, 2014 | 3:10 PM
shanedaff's Avatar
the normal way of pumping the clutch then opening the bleeder valve does not work. also tried leaving the reservoir open and the pedal depressed overnight, someone said that would work and it didnt.
Old Feb 23, 2015 | 11:56 AM
sirdan's Avatar
Hi shanedaff
I have the same problem on my chevy pick up. Did you find a way to bleed that clutch?
Old Mar 27, 2015 | 11:25 AM
sirdan's Avatar
I found the trouble. I had to change de slave cylinder . When I pulled out the transmission, the bushing that is located in the flywhheel felt down between the clutch plate and the pusher plate and I didn't see because I didn't have to remove those parts. When I put back the transmission the bushing stayed in the clutch. So when I tried to bleed the clutch It was as though some air was in the system but it was the bushing who jammed the clutch.
pdrayton
10
May 5, 2024 2:27 PM
blazerhazer
Jun 8, 2015 9:19 PM
Waltmoe
Aug 31, 2007 11:33 AM
chevy3quarta
Jul 27, 2007 5:19 PM
dogz46
Dec 9, 2006 8:34 PM
