Platform: J-body
help with p0118
Old Jul 28, 2009 | 12:09 PM
etay89's Avatar
Question help with p0118
hey, i gotta 98 cavalier base 4dr (sucks now but in time...) but right now, the problem i got is a p0118 that causes my check engine to come on. its the engine coolant temp sensor. i replaced the sensor...and reset the code but the light's still on. i think it maybe a defective sensor...because what will happen is ill reset the code and then the gauge works for like 3-5 miles and then it jus goes back down to a dead cold (the car isn't overheating). i got the sensor from advanced...and think it may be defective. wat are ur thoughts? suggestions? experiences? anything?
thanks
Old Jul 28, 2009 | 2:03 PM
OnDaGround's Avatar
Banned
Check the ECT connector for corrosion. AKA "green stuff".
Old Jul 28, 2009 | 8:25 PM
etay89's Avatar
no green stuff...
Old Jul 29, 2009 | 9:11 AM
OnDaGround's Avatar
Banned
I talked to my friend who is a Master Tech. He said it typically means that the alternator is putting out too high of voltage.
Old Jul 29, 2009 | 10:17 PM
etay89's Avatar
that makes sense...maybe? the guy before has a cable running from the alternator to the positive end of the battery... so maybe if i take away that, it will fix it? cause i do kno that high input means its getting too much juice
Old Jul 30, 2009 | 6:59 AM
OnDaGround's Avatar
Banned
Take a picture of it so I can see it. There should only be one wire unless it's a factory wire. There should be a wire from the alternator to the starter and then another from the starter to the battery. There should not be another wire, but take a pic just to be safe.
Old Jul 30, 2009 | 12:24 PM
etay89's Avatar
ok ill post it later tonight around 10 pm est
Old Jul 30, 2009 | 1:20 PM
OnDaGround's Avatar
Banned
straight, but I won't see it until tomorrow morning.
Old Jul 30, 2009 | 8:21 PM
etay89's Avatar
Old Jul 31, 2009 | 7:20 AM
OnDaGround's Avatar
Banned
Internet blockers won't let me view it. Try downloading it into your album on here and then post it. I will be able to see it then.
