Platform: J-body
Help w/ Disassembling Clutch Hydraulic Line
Old Feb 10, 2010 | 7:21 PM
Sullivaz's Avatar
Default Help w/ Disassembling Clutch Hydraulic Line
I'm having a lot of trouble disconnecting the clutch hydraulic line from the
clutch release cylinder a.k.a. slave cylinder. It says to push in the release slide, but I seem to only get about a couple millimeters w/ it. Is it stuck? What can I use to lubricate it? I assume only brake fluid. Also, should it be easy enough to pull apart w/o any tools? Thank You.
Mike4207
Oct 17, 2014 10:16 AM
BSR29
Jul 13, 2011 10:07 PM
dannyboy11
Mar 11, 2010 7:39 PM
HELPME!
Nov 15, 2009 12:50 PM
candle_soup
K5 Blazer
May 30, 2008 11:18 AM
