Platform: J-body
Replacing pump to filter fuel line
Old Jan 12, 2026 | 10:08 PM
Jiyu's Avatar
Default Replacing pump to filter fuel line
The standard, hard plastic fuel line is shrunk fit/molded to the fitting at the top of the fuel pump, and runs down to the external filter. Is it possible to replace that line with high pressure rubber hose, using clamps?
Thanks
Old Jan 13, 2026 | 8:49 AM
It should work as long as the hose is rated for fuel.
Old Jan 19, 2026 | 2:18 PM
Jiyu's Avatar
Thanks. On the off chance that anyone else is considering this, it does in fact work. I used high-pressure 3/8" fuel line with double hose clamps at each end, and used the opportunity to replace the fuel filter also.
JackBeNimble
Jun 14, 2020 12:46 AM
Ron6519
Feb 11, 2020 9:46 AM
W1KKED1
Oct 30, 2014 10:27 PM
JLanzino
Nov 23, 2011 2:25 PM
reillymax
Chevelle & El Camino
Apr 19, 2008 10:17 PM
