Replacing pump to filter fuel line
The standard, hard plastic fuel line is shrunk fit/molded to the fitting at the top of the fuel pump, and runs down to the external filter. Is it possible to replace that line with high pressure rubber hose, using clamps?
Thanks
Thanks
Thanks. On the off chance that anyone else is considering this, it does in fact work. I used high-pressure 3/8" fuel line with double hose clamps at each end, and used the opportunity to replace the fuel filter also.
W1KKED1
Oct 30, 2014 10:27 PM
