Push Rod Length
Old Mar 16, 2011 | 7:36 PM
JoeHerner's Avatar
Default Push Rod Length
I have a '78 El Camino with a 350 and a 488 cam. What is the length of the push rods I should have?
Old Mar 16, 2011 | 10:31 PM
old dog's Avatar
Default push rods
are you running a hydraulic cam or solid lifter ? stock head's not excessivly milled ? if not stock length should be ok but hardened is better ,if so poly lock's with screw in stud's on the heads and they need to shortened the same length you remove from the heads only in excessive cases .
Old Mar 17, 2011 | 9:15 AM
JoeHerner's Avatar
its a hydraulic cam, stock heads. the guy i bought it off of put a 488 cam in it, but i don't know if he did anything else to it. he had the distributor at a 90 degree to where it is supposed to sit. when it was there, the engine wouldn't idle less than 1500. he didn't have the wires running in the correct firing order either. now that the distributor is placed back in the correct position with the wires running right, i can't even get it to start.
Old Mar 17, 2011 | 9:46 AM
old dog's Avatar
Default push rods
i guess the next thing is to make shure the timing gears are set correctly and not a tooth out !
suzy1328
Feb 20, 2013 5:35 AM
Mayberry40
Mar 8, 2010 9:36 AM
Recceman
May 2, 2009 8:54 AM
Swampwalker3
Dec 7, 2006 6:11 PM
