Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
2005 Chevy Cobalt won't start
Old Mar 20, 2021 | 11:29 AM
Andrew Thompson's Avatar
Question 2005 Chevy Cobalt won't start
My Cobalt won't start, won't even turn over.
There was water in the trunk for quite a while.
I've replaced the battery and the 50A fuse and the connectors and checked the ground in the trunk.
I've checked the fuses and relays in the engine fuse box.
When I turn the key I get no fuel pump sound and no crank.
I don't have a Key Lock symbol on the dash.
I've checked the ODB2 for codes but there were none.
Has anyone experienced this before? What would you try next?
Thanks,
A.
Old Mar 20, 2021 | 6:44 PM
what engine and trans ie auto or manual?
for the starting system
find the crank relay in the underhood fuse box. do you hear and feel it click when someone turns the key to start? if no check the crank 30amp fuse
the fuel pump
same thing
find the fuel pump relay inthe underhood fuse box. do you hear and feel it click when the key is turned to r un. Its should t urn on for 2 seconds at key on. If no, check the f uel pump relay f use 15amp.
post your findings
Old Mar 29, 2021 | 12:04 PM
Default Update
Main Battery Fuse (50A) replaced.
Main Ground reattached.
Fuel Pump Relay replaced.
Running great now.
the fuel pump
same thing
post your findings
ohbugman
Cobalt
Oct 23, 2018 10:44 PM
Dimond_Mae
Cobalt
May 29, 2017 8:10 PM
Brian Crowe
Cobalt
Jan 2, 2017 9:42 AM
chevythedog
Cobalt
Apr 30, 2011 7:05 PM
ideaboomer
Cobalt
Oct 4, 2009 11:07 AM
