Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
2006 cobalt ac blower will not come on
Old Mar 17, 2009 | 6:27 PM
kilgrinus's Avatar
Default 2006 cobalt ac blower will not come on
i have replaced the motor and resistor but still nothing. 12 volts present at motor connector until connected to motor then nothing. checked all associated relays and fuse with no luck. i just cant figure this on out. any ideas?
Old Mar 23, 2009 | 10:07 AM
shawnvw's Avatar
Banned
Sounds like a bad relay. according to the diagram I am looking at, the relay is an internal
part of the BCM.
A couple things to try, first of all, with the motor plugged in, and the key on, use a jumper
lead to ground, and touch it to the orange wire. Does the motor come on? if yes, the problem
is on the ground side, if no, then the problem is on the battery side of the circuit.
Old Mar 24, 2009 | 11:01 PM
kilgrinus's Avatar
i have already tested all the relays and fuses and jumped power and ground and have determined the problem to be on the pos side just need to locate where. i will get into it this weekend
Old Mar 25, 2009 | 6:17 PM
shawnvw's Avatar
Banned
how did you test the relay if its an integral part of the BCM?
Old Feb 19, 2015 | 3:14 PM
connershriner12's Avatar
Default cobalt ls 06
we have a cobalt ls 06 with a broken fan ****. Took it apart and noticed that it was burnt n also the harness is burnt do any of u guys know the part number or what the part is called thank
in advance for your help
Old Feb 20, 2015 | 3:57 AM
Try running 12 volts to the motor directly from the battery to see if the motor runs. This will tell you if the motor is good.
Old Feb 22, 2015 | 1:01 AM
sledge.impy's Avatar
gm parts direct .com should help you dig it out
Old Feb 26, 2016 | 7:55 AM
gmanjimmy's Avatar
Default "Flaky" connection at motor.
I got in my 06 Cobalt this morning and Blower would not turn on. I checked all fuses and relays but nothing seemed bad. When I touched the two wires going into the blower under the passenger side dash, it came on. When I pushed on the wires, however, it seems the fan RPMs went down. When I pulled on them a little bit it, seemed to blow at normal speed. Will investigate further this weekend.
8920mike
Cobalt
May 6, 2013 10:26 AM
gotstylez
Dec 3, 2010 8:43 PM
deere1
Jul 29, 2008 3:14 PM
suedeboogie
Apr 19, 2007 4:28 PM
jbronc88
Mar 22, 2007 11:14 AM
