Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
cobalt wont start
Old Jul 26, 2014 | 2:26 AM
jpadgett230's Avatar
Default cobalt wont start
replaced radiator in a 2008 chevy cobalt lt 2.2l due to leak and over heating. had trouble with trans coolant lines leaking that attach to radiator because was missing little plastic rings on line fittings that attach to radiator. got rings from old radiator and was leaking a little bit after messing with for a while. filled with water and started car and ran a bit then shut off and drained radiator to flush. repeated process car temp got to 244 shut off let set a while drained and then added coolant and water mixture. replaced bumper and headlights. now cannot get the car to start and is now leaking from back of engine. hard to see where coolant is coming from but possibly from water pump but not sure if coming from above pump. drips all the way down and off of transmission. car is turning but not starting. radiator holds some water and drip stops but coolant leaks when i add more and worse when i try to crank it over. hope its not the head gasket or related? was never white smoke and dipstick oil looks clean. what could be the problem?
sleepingciv
Jul 25, 2020 1:03 PM
Btmlodzienski
Cobalt
Jul 8, 2014 5:44 PM
mistyweiss
Cobalt
Nov 13, 2013 7:55 PM
TLW64
Cobalt
Aug 23, 2010 1:58 PM
wildboy74ss
Apr 1, 2009 5:10 PM
