Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Keyless Entry
Old Oct 26, 2007 | 5:14 AM
CobaltNewbee's Avatar
Default Keyless Entry
I just purchased a 2007 Cobalt LS and was wondering if it is possible to have a keyless entry system installed in it. The windows and locks are manual (not by choice; by dealership's availability) but would really like a keyless entry system in it. Any suggestions?
Old Oct 26, 2007 | 11:51 AM
MalibuMaxxSS's Avatar
Default RE: Keyless Entry
easiest way would be to get a command start, and have them put the lock modules and relays in..... or find a donor car and swap the panels and relays, basically everythign behind you door panel, your door panel wont have the slot cut out for the power lock button....
It would have been cheaper to have your dealer find and bring one in for you, a little extra freight but this will run you prolly around 700-1000 bucks, time you find the parts and get it all put in, also if its new have a dealer or someone do it or no warranty. although I cant see a dealer bithcing about you adding it, but ya never know
The reason I say go command start is these come with key fobs, if you go GM you will have to buy the fob seperate, and here these can run around 70-100 bucks themselves
Old Oct 26, 2007 | 2:54 PM
I'm not sure finding a donor car is very possible right now. Junked 2007s are few and far between... Do you think an earlier model Cobalt would have compatible parts for the powerlocks?
Old Oct 26, 2007 | 3:02 PM
all should be the same from 05......Pontiac pursuit is the same I beleive or very close as well.....
Old Feb 17, 2008 | 7:53 PM
charlie pachanga's Avatar
Can be done. the tricky part is getting wiring thru molex in door jambs. I personally use directed automate AM2 for key fob and reciever, then use the 524K door lock actuator/controller kit.
Old Feb 17, 2008 | 8:27 PM
shawnvw's Avatar
Banned
yea these cars are one of the easiest cars to put a keyless entry system into. lots of room in the door panels for the actuators, and you can just push the connector in the door jamb inside the vehicle to make room for your wires.
black07LTZ
Feb 3, 2020 6:58 PM
sadalius
Cobalt
Nov 9, 2013 1:50 PM
93Miata
Astro
Mar 1, 2008 1:49 AM
terryrowe007
May 29, 2006 12:30 AM
