Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
my a/c getting warm while idle.
Old Sep 12, 2012 | 1:53 PM
seja's Avatar
Default my a/c getting warm while idle.
Hi! I'm too new for this forum so, I have a problem for my car. You see, my A/C will getting cold while I'm driving, so when I stop at the red light or something, my A/C will getting warm instead of cold. So, I want to fix my car or I will be not happy with hot weather Any suggestion?
Here is the list that I already did.
1) Replace my fuse.
Old Sep 16, 2012 | 10:36 AM
Welcome to the forum..
What year is your vehicle? engine size?
did you replace the fuse because it was bad? which fuse?
Some items to check are that the cooling fan for the engine is coming on when the AC is on.
Have the AC charged checked at a reputable shop
The thermostat for the engine needs to be operating correctly, if the engine over heats it will also cause the AC to stop working correctly..
Old Sep 17, 2012 | 10:54 AM
seja's Avatar
What year is your vehicle? Chevy Cobalt LT 2007
engine size? 2.2L 4-Cyl
did you replace the fuse because it was bad? which fuse? yep and it is A/C clutch's fuse
Have the AC charged checked at a reputable shop - well, my father did check my car's refrigerant level and it's normal.
The thermostat for the engine needs to be operating correctly, if the engine over heats it will also cause the AC to stop working correctly..how I can check that?
Old Sep 17, 2012 | 1:24 PM
kevinkpk's Avatar
Is the clutch engaged at idle?
Old Sep 17, 2012 | 4:32 PM
seja's Avatar
I don't know because I am deaf so I can't hear. (
Old Sep 17, 2012 | 4:49 PM
kevinkpk's Avatar
You can look at it, if the pully is freewheeling then it isn't engaged, if the end is turning, then it is.
Old Sep 17, 2012 | 5:25 PM
seja's Avatar
right now, my father using my car so I can give you a story so you probably can figure it out.
After stop at the red light, I can feel a lot vibrate for a minute or two and then, I feel nothing but little vibrate also my AC become warm instead of cold.
Old Sep 18, 2012 | 11:16 AM
If the fuse was blown once and now you feel a lot of vibration, I suspect there may be an issue with the compressor, I would advise you take it to a professional AC service for check out and inspection...
Old Sep 25, 2012 | 12:31 PM
GM Fixer's Avatar
low on refridgerant my chev does the same
Old Oct 5, 2012 | 3:56 PM
GM Fixer's Avatar
refridgerant is low. go get it recharged go to a dealer
Cowboy93
Oct 12, 2019 8:32 PM
motoxer4533
Cobalt
Feb 5, 2016 5:24 PM
sj2333
Mar 1, 2014 8:42 PM
spenny
Jun 16, 2009 9:10 PM
mefferz
Feb 26, 2008 4:28 PM
