Chevrolet Colorado
Platform: GMT 350, GMT 31XX
2009 Colorado Z71 4wd Reverse Problems
Old Mar 21, 2023 | 9:54 PM
Shellz76's Avatar
Default 2009 Colorado Z71 4wd Reverse Problems
I have a 2009 Colorado Z71 4wd. It will move in forward position but not in reverse. I’m having to have a transponder key made cause of new switch. Went to load on trailer an it wouldn’t roll back. Put *** end up on a floor jack to raise up off ground. Driver side back tire will spin forward but not backwards and passenger side back tire spins both directions. What could cause this? Transmission or rearend
Old Mar 24, 2023 | 9:02 AM
oilcanhenry's Avatar
Sound to me like your front axle or hub has an issue.
Old Mar 24, 2023 | 10:07 AM
Shellz76's Avatar
So why do you say front axle or hub??
Old Mar 26, 2023 | 8:38 PM
Shellz76's Avatar
[QUOTE=Shellz76;488849]I have a 2009 Colorado Z71 4wd. Trying to figure out why it won’t read on obd scan tool. When u turn key to on switch, dah shows …stab system, traction, fault doors. What could all this be
Old Mar 27, 2023 | 10:15 PM
You said that the rear axle was fine. What else but a busted up,front axle or hub?
Old Mar 28, 2023 | 6:32 AM
Shellz76's Avatar
I never mentioned that rear axle as fine. I said that the drive side rear tire WILL SPIN FORWARD but WILL NOT spin BACKWARDS. Passenger rear tire WILL spin BOTH DIRECTIONS. The driver side rear wheel locks up
classicindy650
Mar 29, 2021 6:32 AM
kshamrock628
Colorado
May 20, 2020 9:39 PM
Johnny Mayday
Colorado
Aug 2, 2018 6:13 AM
sldl2004
Colorado
Apr 19, 2014 4:03 PM
1chevman
17
Apr 8, 2009 6:34 AM
