Chevrolet Colorado
Platform: GMT 350, GMT 31XX
AC/Heater stops & starts on its own on my 2005 Colorado
Old Apr 29, 2013 | 1:16 PM
jetco's Avatar
Exclamation AC/Heater stops & starts on its own on my 2005 Colorado
Why would my ac/heat completely stop working & occasionally start working again at any give time? I replaced the resistor & wiring harness & th blower motor works fine on a direct current. Everything works perfect WHEN there's power. Any ideas????
Old Apr 29, 2013 | 2:19 PM
kevinkpk's Avatar
Loose, or dirty connection would be my guess
Old May 4, 2013 | 1:16 AM
ecmjamsit's Avatar
Bad ground!
Mine kept burning out blower motor resistors. On the right inside of the fender is a ground connection with a one piece connector. I cut the connector, soldered all the wires into a copper battery cable crimp type connector, sanded down the fender area to remove the paint. Dabbed a little lithium grease on the fender area and bolted to the fender. It quit burning out resistors. I haven't had a problem since. Same truck 2005 Colorado.
Juliehebdon
Colorado
Aug 30, 2014 12:54 PM
tingtoups
Apr 27, 2014 8:12 AM
thomboz
Aug 9, 2013 9:47 AM
stanman
Camaro
Jan 7, 2012 4:12 AM
mic cole
Jun 23, 2011 5:55 PM
