Chevrolet Colorado
Platform: GMT 350, GMT 31XX
Dingy towing
Old Aug 26, 2016 | 1:19 PM
Rbark's Avatar
Default Dingy towing
Hello all, just bought the Colorado 4x4 and want to know if I can start towing it right away or if I need to drive it for awhile first?
Thanks for any input, Richard Bark
Old Aug 26, 2016 | 1:29 PM
check the owners manual. all the dingy towing information and precautions will be there.
Old Aug 27, 2016 | 10:44 AM
Rbark's Avatar
I did that. I have a friend that was told to not tow his till after 500 miles or so.there is nothing about that under recreation towing section. Most likely they want you to do the brake in period befor towing.
Old Aug 27, 2016 | 4:00 PM
Are you sure your friend heard that right? Yes, do not to tow with a new vehicle as the engine is under a large load from pulling. There is no load when BEING towed.
just make sure with your build, that it is dingy towable. if its auto transmission, the t case must have a neutral setting and an internal oil pump that will spin with the driveshaft.
Old Sep 1, 2016 | 12:26 AM
Rbark's Avatar
Default Battery disconnect
my Colorado is towable as long as I follow the guidelines in the owners manual. My other question is, why do I have to disconnect the battery before towing? What harm would it cause by leaving it connected?
Old Sep 1, 2016 | 8:23 PM
for vehicles with a locking steering wheel the key must be turned on to unlock the wheel.
Old Sep 2, 2016 | 10:35 AM
Rbark's Avatar
Tech2, I understand that one must do that. I'm trying to understand why one has to disconnect the battery before towing. Called my Chevy dealer and got no answers, called GMC support and got no answers either.
Old Sep 2, 2016 | 6:55 PM
if you have to turn the key to accessory to unlock the wheel, it will power up modules and drain the battery.
when you get your tow bar installed on your truck, the shop should explain this.
Old Sep 3, 2016 | 10:55 AM
Rbark's Avatar
So if that's the case, shouldn't I be able to install a battery maintainer for the toad to keep the battery charged when towing?
Old Sep 3, 2016 | 10:55 PM
usually, when they install a tow bar, the wiring harness for the signal lights has a 12v feed to the battery. Your installer will know all this.
try etrailer.com.
