Corvette Since 1953, the All American Sports car, and with the new 2014 C7 model, no end is in sight.
2014 Corvette C7
Platform: Y-body
Latest Corvette C7 News here: CorvetteForum.com
engine stall when warm
Old Nov 1, 2011 | 3:38 AM
roysai's Avatar
Default engine stall when warm
Hi!
Hi!
i have a LS 7 covette engine. It idle smoothly until 20+ minutes and stall. the temperature sensor shows that it is about 78 deg only, while the designed maximum temperature is 120 deg. I have repeated the experiment a few times and it never fail to stall at temperature 78 deg!
some other weird characteristic:
1. The fan on at 70 deg, while according to the supplier it should be starting at 90deg
2. the rpm fluctuates before stalling
3. idling rpm is not constant. sometimes it idle at 1200rpm and other times can be at 800rpm
4. if i run the engine with bonnet open, it doesn't stall. the reason can be probably because the engine temperature does not reach 78 deg.
what makes the engine stall?
Old Nov 1, 2011 | 12:39 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Roysai,
What year is the vehicle and how many miles on it?
Breanne
Chevrolet Customer Service
Old Nov 1, 2011 | 1:23 PM
kevinkpk's Avatar
Does it have a cold air intake?
Old Nov 2, 2011 | 9:12 PM
roysai's Avatar
It is 3 years old and has very low mileage (<5000km). it doesn't have a cold air intake.
Old Nov 14, 2011 | 9:32 PM
Most, if not all, new cars run at about 200*F. Not sure what you've got but sounds like a thermostat that's stuck open.
Old Nov 14, 2011 | 9:44 PM
MDTAHOE's Avatar
Professional Mechanic
Are we talking about celsius
Old Nov 15, 2011 | 3:57 AM
roysai's Avatar
yes. the temperature mentioned is in celcius.
i've solved the problem. it is because of contaminated fuel pipe that leads to fuel filter choke.
thanks for all the suggestions =)
Old Nov 24, 2011 | 10:41 PM
Glad you got it fixed and thanks for reporting back your findings. Might help someone in the future.
warthogcrewchief
Sep 24, 2022 4:37 PM
Itzdwoodduhh
Jul 13, 2015 9:24 PM
mikeryan
Oct 8, 2007 8:26 AM
brygengler
Oct 7, 2007 1:31 PM
An89Chevy
May 21, 2007 11:43 AM
