Chevrolet Cruze
Also Check out CruzeChat.com
Fan running constantly and no a/c
Old Aug 15, 2023 | 7:23 AM
Steph's Avatar
Default Fan running constantly and no a/c
2014 Chevy Cruze LT 1.4:
My a/c stopped working, water pump was leaking, and fan running constantly while vehicle is started, from start until a few mins after it’s turned off. We’ve replaced and checked everything in the a/c system including replacing the a/c compressor, replaced the water pump, filled with antifreeze, changed temp control sensors x2 twice, replaced thermostat and housing, checked fuses and relays, and left battery unhooked for hours. None of this worked. I started it and the fan immediately came on and the a/c is still blowing warm. Am i missing something? Obviously…
Old Aug 28, 2023 | 2:38 AM
danielsandoval_01's Avatar
hi did you find out what was the issue? Im having the same problem, new cooling fan, fixed water pump leak, also jumped a/c compressor and it blowing cold air also, but cant make cooling fan act normal or made a/c working
mikeshaw
Jun 29, 2019 7:56 AM
Nam.alexandria
Cruze
May 16, 2018 10:13 PM
stkeleher5
Cruze
May 31, 2017 7:32 AM
tom5170
Mar 16, 2010 9:41 PM
atis
Sep 22, 2009 2:04 PM
