Fan running constantly and no a/c
2014 Chevy Cruze LT 1.4:
My a/c stopped working, water pump was leaking, and fan running constantly while vehicle is started, from start until a few mins after it’s turned off. We’ve replaced and checked everything in the a/c system including replacing the a/c compressor, replaced the water pump, filled with antifreeze, changed temp control sensors x2 twice, replaced thermostat and housing, checked fuses and relays, and left battery unhooked for hours. None of this worked. I started it and the fan immediately came on and the a/c is still blowing warm. Am i missing something? Obviously…
hi did you find out what was the issue? Im having the same problem, new cooling fan, fixed water pump leak, also jumped a/c compressor and it blowing cold air also, but cant make cooling fan act normal or made a/c working
tom5170
Mar 16, 2010 9:41 PM
