Chevrolet Cruze
Also Check out CruzeChat.com
High engine temp
Old Jul 2, 2018 | 11:42 AM
donsowers83's Avatar
Default High engine temp
2014 cruze LT. Ac off due to high engine temp- normal temp. Check oil- just changed a few hundred miles ago. Engine light on. Power reduced. Service StablilTrak. Service traction control. Cooling fan running fast and still runs after engine is shut off. Motor shaking a lot when running. Happened last night, been sitting all night and still the same. Coolant level is fine. Whay could it be?
Old Jul 2, 2018 | 11:46 AM
You state that the engine light is on. Have the code read! Advance Auto Parts, Autozone, O'Reilly, etc. will read the codes for you for free.
Old May 12, 2023 | 9:23 PM
Jessica 13's Avatar
I have a 2014 Chevy cruise. I've replaced the water coolant housing and the inland hose and it is still doing exactly what that paragraph said the traction lost the loss of power. Now squealing the I'm not sure what really to do to fix it cause. There's no answer on this and my code's there's 14 code that's being set off. Can you please help me
Old May 12, 2023 | 11:23 PM
oilcanhenry's Avatar
You need someone with a scan-tool to read the codes. The auto parts stores will do it for free. Post the codes here.
Stephen Hartman
Uplander
Jun 16, 2024 11:53 PM
emilyrenee2oo5
Cruze
32
Apr 3, 2024 4:06 AM
bs_54
1988 - 1998 (GMT400)
Jan 16, 2019 11:15 PM
mmrister
Cruze
Mar 27, 2018 8:04 AM
mcbridea88
Dec 16, 2010 8:15 AM
