High engine temp
2014 cruze LT. Ac off due to high engine temp- normal temp. Check oil- just changed a few hundred miles ago. Engine light on. Power reduced. Service StablilTrak. Service traction control. Cooling fan running fast and still runs after engine is shut off. Motor shaking a lot when running. Happened last night, been sitting all night and still the same. Coolant level is fine. Whay could it be?
I have a 2014 Chevy cruise. I've replaced the water coolant housing and the inland hose and it is still doing exactly what that paragraph said the traction lost the loss of power. Now squealing the I'm not sure what really to do to fix it cause. There's no answer on this and my code's there's 14 code that's being set off. Can you please help me
