2006 tahoe
Old Mar 19, 2017 | 9:11 AM
mwilkins5868@gmail.com's Avatar
Default 2006 tahoe
I have a 2006 tahoe error codes po172&175 changed maf sill the same codes came up checked fule presure at rail led me to replace fule pump factory fule pump was actualy 2007 model on 2006 non flex fule 2006 tahoe fule rails dont match 2006 either cant find or solve error codes and cant find repair manual tha actualy shows pictures of 2006 tahoe that matches what i actualy have at a total loss
Old Mar 19, 2017 | 9:49 AM
what were the fuel pressure readings?
Is this a flex fuel vehicle or not? Can you rewrite that with punctuation; its confusing?
post a pic of the vehicle so i can see what bodystyle it is. 5.3L?
the only thing that will set rich dtc are:
bad maf
2 bad 02
exhaust leaks
skewed flex fuel sensor readings
high fuel pressure
Old Mar 19, 2017 | 10:47 AM
5.3 its not flex fule i will try to upload photos
Old Mar 19, 2017 | 10:50 AM
with new fule pump 50psi turning key on apox 58 with it started
Old Mar 19, 2017 | 10:57 AM
Old Mar 19, 2017 | 11:00 AM
Old Mar 19, 2017 | 11:01 AM
Old Mar 19, 2017 | 11:17 AM
