Chevrolet Equinox
Platform: Theta
2007 Chevy Equinox Lt
Old Oct 22, 2022 | 3:06 PM
jpiazza55's Avatar
Default 2007 Chevy Equinox Lt
Radio not getting power. Was working but stopped. Fuses are good.
Old Oct 22, 2022 | 11:04 PM
ruley73's Avatar
Is the Retained Accessory Power feature still working after you turn the key off? If not, that could be the problem. There's a relay for RAP, but I don't recall if it's serviceable or built into the interior fuse panel.
Old Oct 23, 2022 | 5:40 AM
jpiazza55's Avatar
I think i saw something in the fuse box that said RAP. Ill check as soon as the sun comes up, thankyou
Old Oct 23, 2022 | 8:29 AM
jpiazza55's Avatar
Default Rap relay top left
I see the relay in the fuse panel.
Old Oct 23, 2022 | 8:43 AM
jpiazza55's Avatar
Doors and windows still work with the key off. No lights on radio tho
Old Oct 23, 2022 | 8:51 AM
jpiazza55's Avatar
Default More info
I bought the car in June from the original owner it only has 55000 miles on it. It was an elderly man and he said the radio had just stopped working so they thought it may have been the fuse. When I when I 1st got it something was draining the battery overnight every night every night and I ended up reading something online that said take the fuse out of the radio so I did that and it stopped draining the battery. Had the fuse's checked, it wasn't that. Was told the radio needed to be reset by a dealership so I went there this past Thursday and they got it to power up it wouldn't at 1st but they don't know how but it powered up and they set it. It worked from Thursday to Saturday morning and then just stopped. When it stopped working yesterday I didn't take the fuse out and it didn't drain the battery overnight so I have no idea what it could be. Any help would be appreciated
Old Oct 23, 2022 | 8:55 AM
jpiazza55's Avatar
When it worked for those couple of days, the speakers in the driver door apparently have a loose wire cause they cut in and out. Could that stop it from working?
Old Oct 23, 2022 | 9:45 AM
Rednucleus's Avatar
swap the two relays, see if it changes anything
Old Oct 23, 2022 | 11:59 AM
jpiazza55's Avatar
The one right next to it?
Old Oct 23, 2022 | 12:11 PM
jpiazza55's Avatar
I swaped them, no radio but the cluster display said Battery Saver Active. It's never said that before. I switched them back out and now it wouldn't turn over. I just jumped it and it started right up.
