Chevrolet Equinox
Platform: Theta
2019 Chevy Equinox TCM issues?
Old Feb 7, 2025 | 8:41 AM
angelica95's Avatar
Default 2019 Chevy Equinox TCM issues?
My car has been driving fine since the day I got it in 2019, however soon as I surpassed 100k miles last month my check engine light came on and the gears act erratic and doesn’t want to shift in the next gear. BUT when I manually clear the check engine light the car runs perfectly again until it pops up again which happens every once in a while…It’s an ongoing issue and I’m not sure what is going on. I know previously gears would jerk into gear sometimes, but didn’t think anything of it. So maybe that was early signs I never recognized?It’s the strangest thing…does anyone have any ideas what’s going on? TIA.
Old Feb 8, 2025 | 1:15 PM
Moonwink's Avatar
Start by having the codes scanned and load testing your battery.
Old Feb 9, 2025 | 3:01 PM
BlueOx's Avatar
With no data there is no telling "what's going on". You'll need to check some things like codes, fluid levels and so on. Follow the data.
Old Feb 9, 2025 | 4:08 PM
angelica95's Avatar
The code is P0700. We checked the battery and was told it was good.
Old Feb 9, 2025 | 4:09 PM
angelica95's Avatar
the code was P0700. We got our battery tested and ran at oriellys and it was fine they said.
Old Feb 9, 2025 | 10:25 PM
Moonwink's Avatar
It sounds like there should be another code. Make sure when it scanned a good scanner is used that will read all the systems. The cheaper scanners will only scan one system. Use the link below to learn more:
Chevy Equinox P0700 Code:
One of the most common problems with the Chevy Equinox is when it throws the P0700 trouble code. A trouble code is a code thrown out by an automatic transmission whenever it detects that there is an issue going on. In the case of the P0700, it is a general code. This means that it should be accompanied by some other code that should tell you the specific problem. It is a OBDII code and not just a GM code.
Paktype
Dec 12, 2024 8:41 PM
Paktype
Nov 16, 2024 11:26 AM
Nissan Sentra
Sep 25, 2024 3:01 PM
Kingba12
Jul 5, 2023 3:33 PM
alaa
Feb 12, 2022 2:14 PM
