Code 430 low efficiency #2 bank
Chevy equinox 2013 changed the y pipe because of leak in the aft part of the flex coupling. Also removed the aft converter because I replaced the transfer case. Had no codes prior to working on the car. After all the work code 430 popped up low efficiency on number 2 bank. Found a small leak at the flange of the converter to y pipe. Fixed, code would not clear. Changed O2 sensor lower on bank two y pipe. Code still will not clear. Check engine lite comes on after driving about 20 miles.
thanks for the help.
steve
steve
I did look at the connector looked okay. No I didn’t change the converter. Installed new gasket at the manifold.
