Chevrolet Equinox
Platform: Theta
Oil Pump Replacement Help
Old February 18th, 2014 | 11:22 AM
Manny83107's Avatar
Default Oil Pump Replacement Help
I'm a mechanic on the side, and i have a customer that needs a new oil pump on their 2005 Equinox, AWD. when i looked underneath, i couldnt quite tell if i can do it without removing the motor. is there an easy way to do it? has anyone done it yet? i looked on ALLDATA to see what they said, but they start their instructions at "remove the oil pan", which cant really be done. thanks guys.
Old February 18th, 2014 | 8:36 PM
ruley73's Avatar
According to the attached instructions, the oil pan can be replaced without pulling the engine. I don't think it will be easy though due to the tight workspace.
Are you sure the oil pump is bad? I ask because they are simple parts that usually last the life of the engine and never need to be replaced.
oil-pan-replacement.pdf
Old February 18th, 2014 | 8:54 PM
Manny83107's Avatar
The customer took the car into a shop, and that's what they diagnosed, but wanted 2G to do it, so I was going to help them for a lot less. Thank you for your input.
Casual Mechanic
June 22nd, 2015 11:20 AM
JohnnyHydro
January 12th, 2014 8:30 PM
Mille Racer 69
September 5th, 2013 9:53 PM
trolea1234
March 3rd, 2009 10:58 AM
larry_chip
April 24th, 2007 11:46 AM
Quick Reply: Oil Pump Replacement Help
