Chevrolet Equinox
Platform: Theta
outside air temp
Old Dec 8, 2018 | 5:13 AM
musicman's Avatar
Default outside air temp
My outside air temp is not showing up on my 2017 Chevy Equinox. How do I get it back on?
Old Dec 9, 2018 | 11:41 PM
oilcanhenry's Avatar
Pretty sure the termister would be located near the very front of the vehicle. Once mine ever goes I wont give it a second thought, frankly.
Old Dec 9, 2018 | 11:56 PM
is the display showing dashes instead of a number -- ?
Old Dec 10, 2018 | 5:11 AM
musicman's Avatar
No it is not
Old Dec 10, 2018 | 5:14 AM
musicman's Avatar
They replaced the ambient temp. sensor and this did not help
Old Dec 10, 2018 | 8:48 PM
what is it displaying? Is there a code set? It may not be a powertrain code but rather a body code so a cheap code reader will not access it. check all modules.
Old Dec 11, 2018 | 4:04 PM
musicman's Avatar
It is showing Day, Date and Time on the Chevy My Link screen. Is there a fuse just for the outside air temp. I had a small fender bender on the right side that is why the replaced the broken temp sensor. Could it be the wrong ambient temp sensor? Thanks for your reply.
Old Dec 11, 2018 | 8:54 PM
no for a fuse...the sensor is fed power from a module. So its missing from the screen since an accident? if yes, go into set up and see if you can change the set up
Old Dec 14, 2018 | 6:56 AM
musicman's Avatar
Thank you, I tried to do a new set up but did not work . Still no temp reading on screen. I also can not seem to find out how to change the temp reading on the auto ac from cel. to far.
Old Mar 28, 2019 | 3:32 PM
musicman's Avatar
The outside Temp is finally fixed, also the temp settings. Chevrolet had to do a Harness repair after they had to R & R bumper and R & R battery fuse block under the hood to gain access and repair the Harness. It was covered by the Warranty. Thank you.
