Chevrolet Equinox
Platform: Theta
Replaced heater core, truck getting no power
Old Oct 7, 2020 | 12:23 PM
Shawna Riley's Avatar
Default Replaced heater core, truck getting no power
I replaced the heater core and put everything back together. The truck is not getting any power and key is stuck. Battery has sparks coming from terminal so it’s not the battery. Replaced relays and still not starting. Any ideas?
Old Oct 7, 2020 | 1:27 PM
kevinkpk's Avatar
Did you unhook both battery terminals? When you say no power, nothing?
Old Oct 7, 2020 | 9:03 PM
the positive was unhooked while the vehicle was being worked on. Both of the terminals are on now but no lights, and the ignition won’t turn and the key is stuck.
Old Oct 7, 2020 | 10:16 PM
Rednucleus's Avatar
How much did you have to tear apart to do the core.
Old Oct 7, 2020 | 11:17 PM
everything forward of the front seats..yep
Old Oct 8, 2020 | 1:41 PM
the whole dash steering. It’s behind the stereo and everything.
yes. Changed the the relays and still nothing.
Old Oct 8, 2020 | 1:44 PM
I pressed the spring to get the key out but I still can’t figure out why it’s not starting.
Old Oct 8, 2020 | 2:16 PM
kevinkpk's Avatar
Not cranking, or not starting? I'd suggest with a test light or voltmeter, look at the ignition/crank circuit. This sounds like it's a point to point voltage check, and eliminate process.
Old Oct 8, 2020 | 7:18 PM
connector not plugged in?
