Chevrolet Equinox
Platform: Theta
Trans fluid service
Old May 19, 2025 | 3:57 AM
Jude143's Avatar
Default Trans fluid service
Hi all.... the manual states that at 75k, the trans fluid should be checked. Im going to assume this can only be done by a mechanic or at the dealer. Will there be a dash warning if the fluid is low???
Old May 20, 2025 | 10:27 AM
ruley73's Avatar
What year and which engine & transmission does it have? I'll assume it's a newer one with either the 6-speed or the 9-speed. You can check it yourself if you know what you're doing, but it doesn't have a dipstick nor does it have a fluid level sensor/warning. Either way, at 75k miles you'll definitely want to get the fluid changed regardless of what the manual says.
Old May 20, 2025 | 3:10 PM
BlueOx's Avatar
the manual states that at 75k, the trans fluid should be checked. 45K is generally accepted, conservatively, as the maintenance point.
[Im] going to assume this can only be done by a mechanic - No any sufficiently talented / equipped owner can perform the work.
or at the dealer. - Again no
Will there be a dash warning if the fluid is low??? Also a no.
bearbait
Mar 25, 2021 9:11 PM
Jwald
Jun 12, 2017 7:32 PM
Pugly
Jun 16, 2014 9:07 AM
wep54
Nov 11, 2013 8:49 AM
Rob2002HD
Sep 7, 2007 7:05 PM
