Chevrolet Equinox
Platform: Theta
Vibration
Old Jan 16, 2020 | 6:26 PM
David DSa's Avatar
Default Vibration
My 2008 equinox LT -180k Kim’s has suddenly started rattling. The whole cabin/steering shakes at a speed 45kmph and stops ~50 kmph, after that the car handles well at other speeds and there is No check engine light.
Could someone point me In The right direction for a fix.
Old Jan 16, 2020 | 7:04 PM
FWD or AWD?
Inspect the tires for bulges or damage. Have the wheels balanced.
Old Jan 16, 2020 | 7:08 PM
David DSa's Avatar
It’s an AWD.
Old Jan 17, 2020 | 1:44 AM
Irish_alley's Avatar
I'm here for the party
try to manually shift it to whatever gear its in at those speeds and see if you go to 55/60kmph. if you still feel it then it might be in the trans.
Old Jan 17, 2020 | 2:06 AM
AWD means it'll have some kind of rear driveshaft. Those usually have universal joints which can go bad and vibrate. Possibly the rear drive axle too. I'm not familiar with the Equinox drivetrain unfortunately, but I would eliminate the wheels as a cause first.
You could try putting the transmission in neutral when you start feeling the vibration and see if it goes away. (obviously don't do this in a busy area)
Old Feb 13, 2020 | 7:54 PM
David DSa's Avatar
This afternoon I got the wheels balanced and rotated. A few days before I heard a whining noise which got louder as speed increased.. The mechanic identified that as left front wheel bearing failure which he fixed.
However the vibration still remains. It is excessive between 45-60 kmph and goes away above and below this speed range.
Old Jun 12, 2020 | 5:05 AM
David DSa's Avatar
It turns out the problem was the driveshaft bearing. With time the vibration got more heavy- only between ~40-50. A couple of days back heard a violent noise under the floor between the driver/ passenger seat.
the mechanic tried but could not take out the driveshaft from the engine side and finally cut it off.
Now I’m driving a 2WD. No issues to report.
Old Jul 31, 2021 | 3:25 PM
Dno36's Avatar
Thanks for posting back David.
Well Done
cyras21
Jun 6, 2022 1:45 PM
K5Enthusiast
Jul 31, 2017 10:03 AM
Mike Gordon
Chevelle & El Camino
Mar 23, 2017 10:44 PM
Radejr
Sep 20, 2013 7:59 AM
amos221
Jan 21, 2007 11:04 PM
