2002 express 5,7 won't start when it rains
Old September 1st, 2014, 9:59 PM
Le_Lama's Avatar
Default 2002 express 5,7 won't start when it rains
Hello , i have a 2002 chevy express that won't start when it rains.
The engine turns and cuts as if the power was going away. When i say it cut i mean the starter stops for a fraction of a second with the lights going down in the dash board. Last time i waited for a few warm days and it starded back .
could it be a bad ground or or maybe water on the ecu the driver side? I have all the stuff to do my tune up but i see it cuting power to the starter and dash i wounder what the f... it could be.
thanks in advance
Jean-Pierre
Old September 1st, 2014, 10:24 PM
jamesweise33@gmail.com's Avatar
There's a drainage cover over the computer under the hood is water going on computer
Old September 2nd, 2014, 12:57 AM
Le_Lama's Avatar
Well i don't see any cover over my computer and there is water that goes on it.
when i pop my hood il look down on the drivers side and there is my computer with water on it. Il will take a picturewhen i get a chance
Old September 2nd, 2014, 1:44 AM
canucklehead's Avatar
When the starter motor is bad, it turns over slowly with a pause between cranks as it fights the engine over TDC. That might be what you are describing. I replaced my starter on my 2002 and never had a similar issue since. Of course load test your battery first, and check all your main grounds and so on.
gumbute
February 29th, 2020 11:26 AM
thaguyerc
Silverado & Fullsize Pick-ups
February 6th, 2014 2:14 PM
rick02camaro
October 21st, 2012 7:07 PM
48fan
14
January 20th, 2007 12:45 AM
48fan
Audio/Visual Electronics
December 29th, 2006 5:44 PM
Quick Reply: 2002 express 5,7 won't start when it rains
