Fuel economy mpg Express 3500 4.8
Re: a 2007 Chevy express 3500 4.8 liter 3:73 4 spd HD Trans. I started with a full tank with 2 bottles of fuel treatment and drove 70 miles today taking it very easy on the highway 60-65 mph, yet it still took 5.5 gallons of gas to refill the tank. This vehicle has extremely low miles, but what a pig! 13-14 mpg going slow on the highway!!! Does anyone know what highway MPG it should be rated? Last week I had to drive to phoenix with speed limit on hwy 10 is 75 mph (I drove 80 mph) and the mileage was horrendous- I could practically see the needle moving. My front tires are 70 psi off road and rear 80 psi. Could off road tires be the problem or something else??? Ouch!
I seen online these express 3500 were rated between 18-20 mpg highway, mine is nowhere near that not loaded & with less than 10k miles on it I would expect at least 18. My 2003 1 ton e-350 ford with a 7.3 diesel loaded gets way better mpg and it has 340,000 miles. Maybe the diesels get better mpg but I assumed the other way around. The big diesel trucks (med duty & 40 ft RV) I drove got 6-7 mpg but they were pulling a lot of weight.
65mph isn't slow. the thing has the aero of a 4x8 plywood sheet. the rating test cycle isn't done driving 65mph. slow down to 50 and see what you get.
diesel engines are 30% or more fuel efficient that a gasser. Any money you save in fuel is offset by higher maintenance and repair of a diesel engine.
this is the rating for a 5.3 but won't be far off a 4.8L
2007 Chevrolet Express 1500/2500 2WD (fueleconomy.gov)
stay with the rated fuel....using premium in a 4.8 will do nothing as its not a high compression engine. It actually slows stock class racers down at the track. at every oil change put a injector cleaner in the tank as preventative maintenance. to clean dirty injectors you need equipment...tank additives don't fix problems.
When I first got my 2500 on the highway it got around 17 on a 150 mile trip, even with a warped rotor. The 3500 was never that good, but it sat a little higher and it was an extended wheelbase. Yours is the next generation and in theory should be equal or better.
I don't think you can judge from just one trip, though. When you buy gas get a receipt and write the odometer reading on it (and how full if you don't fill it up) and keep track over a few weeks. That will give you a more accurate sample.
A diesel will get better fuel economy. But you have to do the math, when I considered going diesel the additional economy did not offset the higher price of the fuel.
jczarn
Express & G-Series Vans
March 20th, 2020 12:47 AM
