01 express brain buster
Old Jan 12, 2021 | 6:35 AM
Brent Vette's Avatar
Default 01 express brain buster
I've been having an issue with my 01 express (5.7). Occasionally when I would start it, it would make a noise like metal rubbing on metal. I would shut the motor off and start it again and the noise would disappear. It didn't sound like a bearing those sound like a stuck pig. I was stopped at the store and the same thing happened metal rubbing noise so I shut it off quickly then tried to start it and nothing completely dead. No fuel pump, no crank, no gauges. Turn the key and nothing happens. I tried jumping the starter and it turned over but wouldn't run. Any ideas before I call my mechanic?
Old Jan 12, 2021 | 7:08 PM
SteveROntario's Avatar
Maybe your starter is getting jammed or your ignition is sticking on "crank".
I would check that and also remove the belts to see if anything is stuck there.
Old Jan 12, 2021 | 7:09 PM
Craig0320's Avatar
I've heard an alternator do this when it was going out.
Landon Stubberfield
Apr 5, 2021 4:03 AM
Mike Sipolt
Dec 29, 2019 5:24 AM
Mike S.
Jun 18, 2018 1:57 PM
Powell
Nov 20, 2012 1:33 PM
moerome
Jan 26, 2008 1:23 PM
