1500 and 2500 Front suspension same?
Old Dec 14, 2021 | 9:19 AM
GeneveConversionVan's Avatar
Default 1500 and 2500 Front suspension same?
This is making my head ache.
Ive been trying to get Bilsteins for my new to me 2006 1500 Express. But it seems I only get rears. or front for 2500. But other brands such as KYB list ther 1500 as the same part number for 2500. So basically if I buy KYB fronts, the fit both 1500 and 2500, but not bilstein.
Old Dec 15, 2021 | 3:07 PM
William Kisselstein's Avatar
Being shocks I would imagine they will work.
Old Dec 16, 2021 | 1:47 PM
Right,
But so far, no online vendor will admit that. All I have asked say "there are no Bilstein for 1500, but we have for 2500".
Old Dec 19, 2021 | 4:33 AM
I'm going to hazard a guess the shocks are a little taller for the 2500.
Do they give an indication of the GVWR for the van the shocks go on? Its possible to have a 2500 with the 9600 lb rating and it then has the same suspension and brakes as a 1-ton. Short of going to a junkyard and comparing between the two (or maybe getting lucky finding people selling control arms with good photos) I don't know how you'd determine if they will bolt up.
You could also look into fronts for a 1500 pickup, which may work better. Will take a little detective work on Rock Auto with part interchanges to figure out what years to go with, the van usually gets the same chassis as the pickups a few years later.
Old Dec 20, 2021 | 11:20 AM
Also my thought (about it being taller) but then, why KYB are same model?
Old Dec 21, 2021 | 2:15 PM
DCSCO's Avatar
Default Shocker
I checked 1500 and 2500 on rock auto and they both take the same Front shock for my year. Check for yourself on your year.
Old Apr 20, 2022 | 6:52 PM
karlr's Avatar
well I can share what I know here... I have an '03 1500 RWD and purchased what I hoped would work: a set of Bilstein 24-024815 for the rear (which are listed for both 1500 and 2500 applications) and a set of Bilstein 24-187435 for the front, which were listed as being for 2500.
Well, it doesn't work. The bolt spacing to attach the shock to the lower a-arm is wider on my van than it is on the Bilstein.
The confusion is that, as far as I can tell, there are 2500's rated for 7300 GVWR (which use the same lower A-arms as the 1500 7300GVWR). This is a snapshot of results for a Express 2500 suspension
So I suspect the front Bilsteins are only mean to work on 2500's with the 8600 GVWR.
It would be really great to know if the lower A-arms were interchangeable, but the differences could be much more substantial (upper a-arms, springs, hubs, steering, even the chassis interface). Hard to know where it ends.
tank1949
Nov 12, 2017 8:45 AM
Pugly
May 1, 2014 3:47 PM
Sneaky
Feb 19, 2014 7:53 PM
katoom400
Jan 15, 2009 8:34 PM
sgmstr
Oct 31, 2008 6:53 PM
