1989 G20 van no longer charging battery.
Old Dec 9, 2023 | 1:15 PM
Balquo's Avatar
Default 1989 G20 van no longer charging battery.
Hello,
My 1989 G20 van died the other day. I found the battery had drained; and once recharging it, I found the alternator was not charging it. I disconnected the plug (see red circle in picture) out of the alternator and tested it with a multimeter. There is no power going to it when the key is turned. Should there be? Is there a relay/fuse that I should check? The second picture showed the fuse area, but nothing there relating to the alternator from what I could see.
Any advice?
Regards
Balquo
Old Dec 9, 2023 | 1:18 PM
Rednucleus's Avatar
Pull your alternator have it checked at your local parts store. I assume putting meter on battery terminals while running shows under 13 volts??
Old Dec 9, 2023 | 1:20 PM
Balquo's Avatar
Yes, 12.6 or around that when not running, and a little less when running.
Old Dec 9, 2023 | 5:58 PM
Rednucleus's Avatar
I'll bet you need a new alternator, get it tested!
rickyralph
Dec 8, 2021 6:14 PM
jimmydriver
12
Apr 21, 2019 8:01 PM
SherronE
May 16, 2017 1:14 PM
jamesgibb12
Jan 8, 2015 8:25 PM
farfarsson
Sep 9, 2013 4:58 AM
