2002 Chevy express 2500 V6 driver side rear brake line
Does anyone happen to know the exact nut and tube size for the brake line on the rear of the driver site. Mine is broken and I’m trying to get a replacement but it appears there are many different options for these vans. Also, is the place one can buy the complete tubing and nut assembly? Any help will be highly appreciated.
jeff739 (September 8th, 2019)
Bought a complete set from here:
https://www.ebay.com/itm/1996-2002-C...72.m2749.l2649
Comes pre bent with all the hardware. Needed a little tweaking to get them right. If one line has issues, the rest will follow. I just changed all mine after rear ending some women on a local street. Pedal went to the floor. Damage minimal, but more excitement then I need or want. The three flex lines are not included.
Big issue was(is) the ABS module. You need a bi directional scanner to bleed it before you can bleed the rest of the system.
Racerx1662
May 13th, 2017 12:35 PM
Racerx1662
May 12th, 2017 1:31 PM
