2002 Chevy express 2500 V6 driver side rear brake line
Old Sep 5, 2019 | 7:34 PM
jeff739's Avatar
Default 2002 Chevy express 2500 V6 driver side rear brake line
Does anyone happen to know the exact nut and tube size for the brake line on the rear of the driver site. Mine is broken and I’m trying to get a replacement but it appears there are many different options for these vans. Also, is the place one can buy the complete tubing and nut assembly? Any help will be highly appreciated.
Old Sep 5, 2019 | 8:15 PM
SteveROntario's Avatar
Dorman may make line sets. You can also look at the brake hose listings on their website to figure out fitting size.
Old Sep 6, 2019 | 8:10 AM
oilcanhenry's Avatar
Should be the one:
https://www.rockauto.com/en/catalog/...ulic+hose,1792
Old Dec 10, 2019 | 2:54 PM
Ron6519's Avatar
Bought a complete set from here:
https://www.ebay.com/itm/1996-2002-C...72.m2749.l2649
Comes pre bent with all the hardware. Needed a little tweaking to get them right. If one line has issues, the rest will follow. I just changed all mine after rear ending some women on a local street. Pedal went to the floor. Damage minimal, but more excitement then I need or want. The three flex lines are not included.
Big issue was(is) the ABS module. You need a bi directional scanner to bleed it before you can bleed the rest of the system.
Arn
Jan 9, 2018 9:44 PM
Racerx1662
May 13, 2017 12:35 PM
Racerx1662
May 12, 2017 1:31 PM
Jfranco
Feb 23, 2017 8:34 AM
Uncle Wick
Oct 31, 2016 12:07 PM
