95 Van Error Code32
Old Oct 19, 2009 | 4:49 PM
caandrew425's Avatar
Default 95 Van Error Code32
My 95 Van Conversion is showing an error code of 32-EGR Malfunction.
What do I need to check to resolve this?
Andy
Old Oct 19, 2009 | 8:31 PM
MDTAHOE's Avatar
Professional Mechanic
Check the vac lines going to the EGR sensor and valve. You need to get a hand held vac pump and manually open the valve and make sure it can hold vacuum. With the truck running use the pump to open the valve, the truck should start to run very bad or stall.
JUNIOR
May 7, 2007 4:56 PM
tshunt01
Feb 19, 2007 12:26 AM
Dash
Nov 16, 2006 2:13 PM
illini33
Oct 29, 2006 1:04 PM
Mother_Trucker
Sep 10, 2006 12:01 AM
