chassis lubrication
Old Jul 31, 2011 | 4:33 PM
tbb2's Avatar
15 Year Member
Default chassis lubrication
Chevy Express 3500 cargo van
The shop manual (page 0-41) lists under "Chassis Lubrication" - "Lubrication Points":
1) Propeller Shaft-Slip Joint
2) Rear Axil Differential
3) Master Cylinder
4) Oil Filter
5) Steering Gear
6) Engine
7) Steering Linkage
8) Wheel Bearings
9) Transmission
Is it my imagination or did they just put everything that has something slippery on it?
Where would I grease the Rear Axil Differential, Master Cylinder, Oil Filter, Engine, or Transmission?
For that matter what do they have to do with the chassis?
Will someone please confirm for me that this list and diagram are for items to be lubricated over all?
There is a second list (page 0-37) that seems more to the point:
1) Front Suspension
2) Ball Joints (@ > 10 degrees F)
3) Steering Linkage
4) Trans Shift Linkage
5) Parking Brake cable GUIDES
Old Jul 31, 2011 | 6:27 PM
tbb2's Avatar
15 Year Member
Default front suspension - ball joints
2003 Chevy Express 3500
From what I understand the ball joints are the only greased parts of the front suspension.
Are there other parts in there I should be looking for?
Old Aug 24, 2011 | 2:48 PM
EnyChevyUK's Avatar
If you are using a grease gun I think the only greasing points are indeed on the front steering linkages, ball joints etc , well thats all I could find when I did mine.
Jerry32
Sonic (Aveo)
Jun 17, 2013 9:33 AM
tbb2
Jul 31, 2011 4:21 PM
in2pro
12
Nov 15, 2010 11:40 PM
JK23112
Jul 11, 2010 8:40 PM
exuL1B47
Apr 30, 2009 8:26 AM
