Express 1500 cranks slowly no start
Old May 28, 2022 | 2:47 PM
overton25's Avatar
Default Express 1500 cranks slowly no start
New to this forum but have a 99 express 1500 new battery, starter, water pump, plugs/wires, fuel pump. I let it sit for a few days without cranking and now it want start. Starts slowly even with booster cables on.
Old May 28, 2022 | 5:14 PM
Try cranking it with starting fluid and see if starts any better.
Also try removing the serpentine belt.
Old May 30, 2022 | 2:34 AM
overton25's Avatar
Have tried starting fluid with no luck, but haven’t tried taken belt off. Will that mess with my timing?
Old May 30, 2022 | 9:51 AM
No, the serpentine belt has nothing to do with timing!
Old May 30, 2022 | 10:29 AM
overton25's Avatar
But what good would removing the belt do, don’t you need the belt to turn the flywheel to get motor cranked
Old May 30, 2022 | 11:58 AM
No it doesn't turn the flywheel. It turns the alternator, water pump, etc. You can't run it for a long time after removing the belt if it does start. It would just put less drag on the starter. and might crank a little faster.
Old May 30, 2022 | 12:16 PM
It's a quick and easy way to eliminate several things that might cause a slow crank. A seized AC compressor, alternator, power steering pump, etc.
You have a flywheel on the front of your engine? Do you drive one of these?
Old May 30, 2022 | 12:21 PM
You should also check all your ground connections.
Battery to body,
Engine block to body strap,
Ignition component grounds,
etc.
Old May 30, 2022 | 2:09 PM
overton25's Avatar
Ok all of you that are trying to help (thank you big time by the way!)I took the belt off and still want start. I’ve got plenty of volts/amps, the starter is sounding and acting strong. All and any suggestions are welcome
Old May 30, 2022 | 2:41 PM
Is the check engine light on?
