Front Steering? RUBBER FAIL?...Disintergrated?
Old Feb 27, 2019 | 11:44 AM
JAMBUS's Avatar
Question Front Steering? RUBBER FAIL?...Disintergrated?
So I was hitting my Zirc Points and saw that I have this issue. Looks like the rubber bushing that encased this rod, I think it is a steering rod?? Directly under my bumper and back about 16 inches.
Attached pics. Is this an easy fix? I have been hearing a bump every so often. The one on the driver side is crumbling like stale Oreos. Actually Oreos do not last past 24 hours in my house so that is a bad analogy. Falling apart like dried rubber. Any help is appreciated.
JAMBUS CREW
Old Feb 27, 2019 | 1:25 PM
It's made of one piece and it's not attached to the steering wheel in any way, so it would be pretty hard to steer with it
It's called a stabilizer bar. It's basically a big spring and it keeps the van from leaning over during turns. The bushings are easy to find and super cheap ($3) on rockauto.com
Old Feb 28, 2019 | 7:18 PM
JAMBUS's Avatar
Talking Thanks SO Much
Mountainmanjoe...Ordered the parts and have the socket wrench...oh and a beer or 2 ready for when they get here. You have my vote for Chevy Forum Mountain Man of The Year!!
JAMBUS CREW says THANKS SO MUCH!
Old Feb 28, 2019 | 7:42 PM
I'm honored.
Old Mar 1, 2019 | 10:26 PM
jimmydriver's Avatar
Start soaking that rusty bolt with some WD-40 or some such thing.
Old Mar 2, 2019 | 3:32 AM
oilcanhenry's Avatar
Yeah, I noticed all that metal corrosion too.
OP must live somewhere that they still use road salt in the winter, as thats the only time I have seen metal corrosion get that awful.
Old Mar 2, 2019 | 11:14 AM
cablesplicer's Avatar
Default Easy fix .
It is an easy fix . I have done mine countless times over 20 years . Here in ohio i wish they still used only salt because what ever there useing now is worse . It will eat metal 3 times faster then salt ever did. I brought life time mounts and never had to pay for them again . Good luck and happy motoring .
Old Mar 2, 2019 | 3:43 PM
canucklehead's Avatar
I wanna know the source of the oil and grease on your anti sway bar, and the tie rod, and control arm.....lol
Old Mar 2, 2019 | 4:27 PM
It looks like someone was trying to lube the bushing, which is bad. Oil breaks down rubber.
