G10/G20/G30 old sliding door repair, new part!
Old Feb 24, 2025 | 9:05 AM
  #31
Bczee's Avatar
Default Translate
Is there an English version of this item link ?
Old Feb 24, 2025 | 11:40 AM
  #32
Andreas G20's Avatar
Default translation is in description
In the description you'll find an eglish translation. You can also use your browser to translate or copy and paste text to deepl.com. Shouldn't be a problem. But you can always ask the seller questions. You can also ask here!
Old Feb 24, 2025 | 11:44 AM
  #33
Default What happend to the assembly? Answer is here:
Originally Posted by Mwatkins8290
Hi I was wondering if anyone knows where to get the whole assembly. I just bought my GMC vandura and the top roller is all that's holding the door on the other side has broke completely off.
The bushings on the door side of the "arm" are worn out! If you don't change them before the assembly breaks you're f....
You'll have to find the assembly on a junkyard. I just did it over here in Germany. The assembly was broken like this. He was lucky to find a used one. We changed the bushings and the guide block (plastic slider) and the door acts like new! It was possible to get the right gap between the door and roof side rail. It should be about 0.25-inch or 4.5mm. To accomplish this adjustment loosen the upper rear hinge to door bolts and align the rear edge of the door up or down. Try after installing the new bushings and guide block. Maybe you'll not be able to restore 0.25-inch but you'll come close! I hope I can upload a video of this fix on youtube.
Better change the bushings before it happens! I still have some of them.
https://www.ebay.de/itm/146397554217
Old Jun 14, 2025 | 8:48 PM
  #34
normand69's Avatar
ou on peut rétrouver cet article
Old Feb 17, 2026 | 12:31 AM
  #35
kmcharbs's Avatar
Default Nylon replacement block
Andrdo you have anymore of those nylon blocks or can tell me where you got them. Im in need of one.
lars1980
Feb 17, 2025 8:49 AM
Maineflyer
Dec 7, 2016 6:28 AM
computerji
Nova & Chevy II
Feb 27, 2016 10:29 PM
Jhowey
Feb 19, 2016 9:31 AM
BigBadOsker
Oct 27, 2014 5:37 PM
