Helpppppp!!!!
Helpppppp!!!!
1993 g20 5.7 l v8 Transmission issue that I had it solved ,but the remanufactured is a 4wd with a short shaft oversight . However I found BUSTED FLYWHEEL I REPLACED . I then reinstalled old trans drove down the road .Filled torq convert via pump (no pint add to TQ) transmission guy said forward and reverse gears to fill you will fill it pull. Well I did I drove it back and forth then stopped working except very low gear .
I need advice do I remove fill converter reinstall?
Thanks
Thanks
what?
The following 2 users liked this post by mountainmanjoe:
DavidDeBord (April 14th, 2022),
VanKo (September 20th, 2021)
How much transmission fluid have you put in? It takes something close to 14qts I think.
4l60e parts dont work for long in a 4l80e
scoobdj01
11
July 20th, 2018 10:54 AM
Mr-Magoo
December 19th, 2014 4:46 PM
Mille Racer 69
17
January 5th, 2011 4:18 PM
