Helpppppp!!!!
1993 g20 5.7 l v8 Transmission issue that I had it solved ,but the remanufactured is a 4wd with a short shaft oversight . However I found BUSTED FLYWHEEL I REPLACED . I then reinstalled old trans drove down the road .Filled torq convert via pump (no pint add to TQ) transmission guy said forward and reverse gears to fill you will fill it pull. Well I did I drove it back and forth then stopped working except very low gear .
I need advice do I remove fill converter reinstall?
Thanks
Thanks
scoobdj01
11
Jul 20, 2018 10:54 AM
Mr-Magoo
Dec 19, 2014 4:46 PM
Mille Racer 69
17
Jan 5, 2011 4:18 PM
