High Idle
Old Mar 11, 2024 | 7:10 AM
Brownie289's Avatar
Default High Idle
1992 G30, high idle, replaced the idle control valve, was running better.
Now when I drop into gear it stalls, like it’s getting no gas.
Then hard to restart.
New throttle body time?
Thanks!
Old Mar 11, 2024 | 9:32 PM
Triaged's Avatar
I'm guessing 5.7l?
You can make your own cable for the scan tool... I might have thrown out the one I made way back when.
https://charm.li/Chevy%20Truck/1992/.../Idle%20Speed/
Old Mar 11, 2024 | 9:33 PM
Triaged's Avatar
WinALDL - 160 baud ALDL reader
Old Mar 12, 2024 | 11:02 AM
Brownie289's Avatar
Default Thanks!
Tried a code reader says no issues
Yes it’s a 5.7.
Old Mar 12, 2024 | 10:38 PM
Triaged's Avatar
You aren't looking for a code. You need a scan tool that can look at the IAC count. There are lots of options for OBD2 but with pre-OBD2 ALDL you're looking at either expensive or DIY. I provided the DIY cheap version. Just need a serial to USB cable, the program, and a DIY cable made from some parts from "radio shack". Good luck finding a local electronics store.
Old Mar 13, 2024 | 7:40 PM
Brownie289's Avatar
Yes thank you I used a scan tool. Count was 1 - 2. Meaning ok.
I did disconnect the battery after too, supposed to clear the ECM.?
Old Mar 13, 2024 | 7:48 PM
Brownie289's Avatar
The only thing I have done to it was change the idle control valve…
Old Mar 14, 2024 | 12:44 AM
Triaged's Avatar
1-2 is too low isn't it? Charm says 5-30. Do you have a vacuum leak? Bad PCC?
Old Mar 14, 2024 | 6:03 AM
Brownie289's Avatar
I haven’t really focused on a vacuum leak, just because this came on suddenly after I changed the idle control valve, actually it ran better after I changed the valve, took it for a ride performed well. A few days later this problem developed.
The book that came with the reader said a flash of 1 then 2 meant no issues.
Old Mar 14, 2024 | 2:32 PM
Code 12 indicates the computer's self-diagnostic system is functioning properly.
It does not indicate "no issues", since you will still see code 12 along with other trouble codes.
